ArcGIS.Core.CIM Namespace / CIMMarkerPlacementPolygonCenter Class
Properties Methods Events
    CIMMarkerPlacementPolygonCenter Class Members
    The following tables list the members exposed by CIMMarkerPlacementPolygonCenter.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets a value indicating whether the marker should be clipped if it extends pasts the boundary of the polygon.
    Public Property Gets or sets the method used to determine the polygon center.
    Public Property Gets or sets the value which offsets the marker horizontally from the center.
    Public Property Gets or sets the value which offsets the marker vertically from the center.
    Public Property Gets or sets a value indicating whether to consider individual geometry parts or the whole geometry. (Inherited from ArcGIS.Core.CIM.CIMMarkerPlacement)
    Public Property Gets or sets the primitive name. (Inherited from ArcGIS.Core.CIM.CIMMarkerPlacement)
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMMarkerPlacementPolygonCenter.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMMarkerPlacementPolygonCenter with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMMarkerPlacementPolygonCenter and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
