ArcGIS.Core.CIM Namespace / CIMKnowledgeGraphInvestigation Class
    CIMKnowledgeGraphInvestigation Class Properties
    For a list of all members of this type, see CIMKnowledgeGraphInvestigation members.
    Public Properties
     NameDescription
    Public Property Gets or sets the custom properties of the investigation. Custom properties are limited to key / value pairs of strings and developers are fully responsible for stored content.
    Public Property Gets or sets the data connection.
    Public Property Gets or sets the array of Data Loading Configurations referenced by this Investigation. All configurations are expected to have unique names.
    Public Property Gets or sets the array of Data Model Visualizations referenced by this Investigation. All Data Model Visualizations are expected to have unique names.
    Public Property Gets or sets the array of Filtered Find Paths Configurations referenced by this Investigation. All configurations are expected to have unique names.
    Public Property Gets or sets the metadata URI. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the name. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the array of query definitions referenced by this Investigation. All query definitions are expected to have unique names.
    Public Property Gets or sets the array of search definitions referenced by this Investigation. All search definitions are expected to have unique names.
    Public Property Gets or sets the time the source was last modified, as of the last sync. Used to detect when another sync is needed. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the source portal URI of the item. Set if sourced from an external item such as an item on a portal. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the source URI of the item. Set if sourced from an external item such as an item on a portal. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets the array of Knowledge Graph Investigation Type Infos referenced by this Investigation. All infos are expected to have unique type names.
    Public Property Gets or sets the URI of the definition. Typically set by the system and used as an identifier. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Public Property Gets or sets a value indicating whether the CIM definition accesses metadata from its data source (the default behavior), or if it has its own metadata stored in the project. (Inherited from ArcGIS.Core.CIM.CIMDefinition)
    Top
