ArcGIS.Core.CIM Namespace / CIMFloodSimulationDepthRaster Class
Properties Methods Events
    CIMFloodSimulationDepthRaster Class Members
    The following tables list the members exposed by CIMFloodSimulationDepthRaster.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the linear unit.
    Public Property Gets or sets the name of the object. It holds the layer URI when a raster is used. Otherwise it holds the displayed value. (Inherited from ArcGIS.Core.CIM.CIMFloodSimulationObject)
    Public Property Gets or sets the data connection for the raster source.
    Public Property Gets or sets the raster index for multidimensional rasters.
    Public Property Gets or sets a value indicating whether the object is visible. (Inherited from ArcGIS.Core.CIM.CIMFloodSimulationObject)
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMFloodSimulationDepthRaster.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMFloodSimulationDepthRaster with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMFloodSimulationDepthRaster and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
