ArcGIS.Core.CIM Namespace / CIMLevelLayerProperties Class
Properties Methods Events
    CIMLevelLayerProperties Class Members
    The following tables list the members exposed by CIMLevelLayerProperties.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the name of the field containing the facility id (a foreign key back to the Facility feature class).
    Public Property Gets or sets the URI for the Indoors Level layer in the map CIM.
    Public Property Gets or sets the name of the field containing the level id.
    Public Property Gets or sets the name of the field containing the level number.
    Public Property Gets or sets the name of the field containing the level "long" name.
    Public Property Gets or sets the name of the field containing the level "short" name.
    Public Property Gets or sets the sublayer ID when the Level layer is a sublayer within a dynamic map service layer.
    Public Property Gets or sets the name of the field containing the vertical order for the level.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMLevelLayerProperties.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMLevelLayerProperties with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMLevelLayerProperties and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
