| Name | Description | |
![]() | CIMFormImageInput Constructor |
The following tables list the members exposed by CIMFormImageInput.
![]() | InputMethod | Gets or sets the supported input methods used to attach an image. |
![]() | MaxImageSize | Gets or sets the number of pixels on the longest edge depending on orientation. Larger images will be resized and aspect ratio is maintained. If 'maxImageSize' is Double.NaN, images will not be resized. |
![]() | Clone | Creates a deep copy of CIMFormImageInput. |
![]() ![]() | FromJson | Reconstructs the CIMFormImageInput with a specified state from a JSON encoding. |
![]() | GetSchema | Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | ReadXml | Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | ToJson | Overridden. Creates a JSON encoding of the CIMFormImageInput and its current state. |
![]() | WriteXml | Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | RaisePropertyChanged | Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | ReadXmlElement | Overridden. Reads the child element inside the reader. |
![]() | WriteXmlElements | Overridden. Writes a child element to the writer. |
![]() | PropertyChanged | Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject) |
