ArcGIS.Core.CIM Namespace / CIMFormRelationshipElement Class
Properties Methods Events
    CIMFormRelationshipElement Class Members
    The following tables list the members exposed by CIMFormRelationshipElement.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets a string that describes the element in detail.
    Public Property Gets or sets an integer that indicates the maximum number of records to display. If set (or defaulted) to -1, there is no maximum.
    Public Property Gets or sets how related records should be displayed.
    Public Property Gets or sets the name of an Arcade expression that returns a boolean value. When this expression evaluates to 'true', the element is editable. When the expression evaluates to 'false' the element is not editable. If the referenced related table is not editable, the editable expression is ignored and the element is not editable.
    Public Property Gets or sets a string value indicating what the element represents.
    Public Property Gets or sets the array of orderByField objects indicating the display order for the related records, and whether they should be sorted in ascending or descending order.
    Public Property Gets or sets the name of the relationship as defined in the feature layer definition.
    Public Property Gets or sets the name of an Arcade expression that returns a boolean value. When this expression evaluates to 'true', the element is displayed. When the expression evaluates to 'false' the element is not displayed. If no expression is provided, the default behavior is that the element is displayed.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMFormRelationshipElement.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMFormRelationshipElement with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMFormRelationshipElement and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
