| Name | Description | |
![]() | CIMFormTextAreaInput Constructor |
The following tables list the members exposed by CIMFormTextAreaInput.
![]() | MaxLength | Gets or sets the this represents the maximum number of characters allowed. If set (or defaulted) to -1, the value is derived from the length property of the referenced field in the service. |
![]() | MinLength | Gets or sets the this represents the minimum number of characters allowed. If set (or defaulted) to 0, there is no minimum constraint. |
![]() | Clone | Creates a deep copy of CIMFormTextAreaInput. |
![]() ![]() | FromJson | Reconstructs the CIMFormTextAreaInput with a specified state from a JSON encoding. |
![]() | GetSchema | Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | ReadXml | Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | ToJson | Overridden. Creates a JSON encoding of the CIMFormTextAreaInput and its current state. |
![]() | WriteXml | Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | RaisePropertyChanged | Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | ReadXmlElement | Overridden. Reads the child element inside the reader. |
![]() | WriteXmlElements | Overridden. Writes a child element to the writer. |
![]() | PropertyChanged | Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject) |
