ArcGIS.Core.CIM Namespace / CIMFormTextElement Class
Properties Methods Events
    CIMFormTextElement Class Members
    The following tables list the members exposed by CIMFormTextElement.
    Public Constructors
     NameDescription
    Public Constructor
    Top
    Public Properties
     NameDescription
    Public Property Gets or sets the string value indicating the text to be displayed within the formTextElement.
    Public Property Gets or sets the format of the 'text' property. Default is PlainText.
    Public Property Gets or sets the name of an Arcade expression that returns a boolean value. When this expression evaluates to 'true', the element is displayed. When the expression evaluates to 'false' the element is not displayed. If no expression is provided, the default behavior is that the element is displayed.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMFormTextElement.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMFormTextElement with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMFormTextElement and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
