ArcGIS.Desktop.Editing.COGO Namespace / BaseCurveDefinition Class / CalculateChordLength Method
    Calculates the chord length for the curve.
    Syntax
    Public Function CalculateChordLength() As Double
    public double CalculateChordLength()
    Return Value
    The curve chord length.
    Exceptions
    ExceptionDescription
    The chord length cannot be calculated.
    Remarks
    You should use CanCalculateChordLength prior to calculating the chord length to determine if the curve definition has the appropriate values. The chord length can be calculated if the curve definition contains a Radius and a CentralAngle or a Radius and an ArcLength.
    Requirements
    ArcGIS Pro version: 3.7 or higher.
