IsValid Method (CircularArcDefinition)
Gets if the curve definition is valid. That is, if the minimum set of values are defined.
Public Function IsValid() As Boolean
Return Value
True if the definition has a valid set of values.
ArcGIS Pro version: 3.7 or higher.
