ArcGIS.Desktop.Editing.COGO Namespace / COGOLineBuilder Class / CreateCOGOCircularArc Method / CreateCOGOCircularArc(TangentCurveDefinition) Method
The tangent arc definition.
Example
    Creates a circular arc COGOLine for use in a Traverse
    Syntax
    Public Overloads Shared Function CreateCOGOCircularArc( _
       ByVal tangentCurveDefinition As TangentCurveDefinition _
    ) As COGOLine
    public static COGOLine CreateCOGOCircularArc(
       TangentCurveDefinition tangentCurveDefinition
    Parameters
    Return Value
    Exceptions
    Example
    Create a COGOLine defined by a tangent curve
    var tangentCircArcDef = new TangentCurveDefinition
      Radius = 169.0,
      ArcLength = 52.40
    var cogoTangentArc = COGOLineBuilder.CreateCOGOCircularArc(tangentCircArcDef);
    var tangentCircArcDef2 = new TangentCurveDefinition
      Radius = -201.0,
      ChordLength = 23.24
    var cogoTangentArc2 = COGOLineBuilder.CreateCOGOCircularArc(tangentCircArcDef2);
    var tangentCircArcDef3 = new TangentCurveDefinition
      Radius = 169.0,
      CentralAngle = 44.0
    var cogoTangentArc3 = COGOLineBuilder.CreateCOGOCircularArc(tangentCircArcDef3);
    Create a Traverse
    List<COGOLine> lstCOGOLines = new();
    var direction = ParcelUtilities.Instance.ConvertQuadrantBearingDMSToNorthAzimuthDecDeg("S7-46-51-E");
    lstCOGOLines.Add(COGOLineBuilder.CreateCOGOStraightLine(nAzDirection, 61.45)); //1
    lstCOGOLines.Add(COGOLineBuilder.CreateCOGOStraightLine(166.2625, 37.22));//2
    lstCOGOLines.Add(COGOLineBuilder.CreateCOGOStraightLine(255.2833333, 71.4));//3
    var circArcDef = new CircularArcDefinition
      Radius = -201.0,
      ArcLength = 45.29,
      ChordDirection = ParcelUtilities.Instance.ConvertQuadrantBearingDMSToNorthAzimuthDecDeg("N21-47-57W")
    lstCOGOLines.Add(COGOLineBuilder.CreateCOGOCircularArc(circArcDef));//4
    var tangentCurveDef = new TangentCurveDefinition
      Radius = 169.0,
      ArcLength = 52.40
    lstCOGOLines.Add(COGOLineBuilder.CreateCOGOCircularArc(tangentCurveDef));//5
      Radius = 13.0,
      ArcLength = 22.98
    lstCOGOLines.Add(COGOLineBuilder.CreateCOGOCircularArc(tangentCurveDef));//6
      Radius = -281.0,
      ArcLength = 73.68
    lstCOGOLines.Add(COGOLineBuilder.CreateCOGOCircularArc(tangentCurveDef));//7
    var spatialReference = map?.SpatialReference;
    var travParcel = new Traverse(spatialReference);
    await travParcel.AddCoursesAsync(lstCOGOLines);
    if (travParcel.IsValid())
      ; //insert code to use the traverse
    Requirements
    ArcGIS Pro version: 3.7 or higher.
