ArcGIS.Desktop.Editing.COGO Namespace / TangentCurveDefinition Class
Members Example
    Defines the parameters for a tangent curve in the context of a traverse.
    Syntax
    Public NotInheritable Class TangentCurveDefinition
       Inherits BaseCurveDefinition
    public sealed class TangentCurveDefinition : BaseCurveDefinition
    Remarks
    A tangent curve must be defined with a BaseCurveDefinition.Radius and one of the following BaseCurveDefinition.ChordLength, BaseCurveDefinition.CentralAngle, BaseCurveDefinition.ArcLength.
    Once the tangent curve parameters have been defined, use the COGOLineBuilder.CreateCOGOCircularArc method to create a COGOLine. Once a line has been created, use Traverse.AddCourse to add it to a traverse.
    Example
    Create a COGOLine defined by a tangent curve
    var tangentCircArcDef = new TangentCurveDefinition
      Radius = 169.0,
      ArcLength = 52.40
    var cogoTangentArc = COGOLineBuilder.CreateCOGOCircularArc(tangentCircArcDef);
    var tangentCircArcDef2 = new TangentCurveDefinition
      Radius = -201.0,
      ChordLength = 23.24
    var cogoTangentArc2 = COGOLineBuilder.CreateCOGOCircularArc(tangentCircArcDef2);
    var tangentCircArcDef3 = new TangentCurveDefinition
      Radius = 169.0,
      CentralAngle = 44.0
    var cogoTangentArc3 = COGOLineBuilder.CreateCOGOCircularArc(tangentCircArcDef3);
    Create a Traverse
    List<COGOLine> lstCOGOLines = new();
    var direction = ParcelUtilities.Instance.ConvertQuadrantBearingDMSToNorthAzimuthDecDeg("S7-46-51-E");
    lstCOGOLines.Add(COGOLineBuilder.CreateCOGOStraightLine(nAzDirection, 61.45)); //1
    lstCOGOLines.Add(COGOLineBuilder.CreateCOGOStraightLine(166.2625, 37.22));//2
    lstCOGOLines.Add(COGOLineBuilder.CreateCOGOStraightLine(255.2833333, 71.4));//3
    var circArcDef = new CircularArcDefinition
      Radius = -201.0,
      ArcLength = 45.29,
      ChordDirection = ParcelUtilities.Instance.ConvertQuadrantBearingDMSToNorthAzimuthDecDeg("N21-47-57W")
    lstCOGOLines.Add(COGOLineBuilder.CreateCOGOCircularArc(circArcDef));//4
    var tangentCurveDef = new TangentCurveDefinition
      Radius = 169.0,
      ArcLength = 52.40
    lstCOGOLines.Add(COGOLineBuilder.CreateCOGOCircularArc(tangentCurveDef));//5
      Radius = 13.0,
      ArcLength = 22.98
    lstCOGOLines.Add(COGOLineBuilder.CreateCOGOCircularArc(tangentCurveDef));//6
      Radius = -281.0,
      ArcLength = 73.68
    lstCOGOLines.Add(COGOLineBuilder.CreateCOGOCircularArc(tangentCurveDef));//7
    var spatialReference = map?.SpatialReference;
    var travParcel = new Traverse(spatialReference);
    await travParcel.AddCoursesAsync(lstCOGOLines);
    if (travParcel.IsValid())
      ; //insert code to use the traverse
    Inheritance Hierarchy
    System.Object
       ArcGIS.Desktop.Editing.COGO.BaseCurveDefinition
          ArcGIS.Desktop.Editing.COGO.TangentCurveDefinition
    Requirements
    ArcGIS Pro version: 3.7 or higher.
