ArcGIS.Core.Data Namespace / CoreDataExtensions Class / CreateInEditOperation Method
The ArcGIS.Core.Data.UtilityNetwork.Telecom.CircuitManager instance used to create the circuit.
The circuit to create.
    Inserts a circuit row in the circuit table with the provided argument's values. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Shared Sub CreateInEditOperation( _
       ByVal circuitManager As CircuitManager, _
       ByVal circuit As Circuit _
    public static void CreateInEditOperation(
       CircuitManager circuitManager,
       Circuit circuit
    Parameters
    circuitManager
    circuit
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    Requirements
    ArcGIS Pro version: 3.7 or higher.
