ArcGIS.Core.Data Namespace / CoreDataExtensions Class / VerifyInEditOperation Method
The ArcGIS.Core.Data.UtilityNetwork.Telecom.CircuitManager instance used to verify the circuits.
The circuits whose status to update.
The options that will describe how the circuit will be verified.
    Updates the status of a list of circuits. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Parameters
    circuitManager
    circuitNames
    circuitVerifyOptions
    Return Value
    The information about the operation over each circuit.
    Exceptions
    ExceptionDescription
    A geodatabase-related exception has occurred.
    Requirements
    ArcGIS Pro version: 3.7 or higher.
