ArcGIS.Desktop.Mapping Namespace / KnowledgeGraphMappingExtensions Class / ClearLinkChartContent Method
The link chart to clear content.
Example
    Clears the link chart map content. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Shared Sub ClearLinkChartContent( _
       ByVal linkChart As Map _
    public static void ClearLinkChartContent(
       Map linkChart
    Parameters
    linkChart
    Exceptions
    ExceptionDescription
    Map is not a link chart or does not contain a Knowledge Graph layer.
    Remarks
    You should use CanClearLinkChartContent prior to this method.
    Example
    Clear all content from a link chart
      await QueuedTask.Run(() =>
        //Get the link chart to be cleared of content
        var mapPanes = FrameworkApplication.Panes.OfType<IMapPane>().ToList();
        var mapPane = mapPanes.First(
          mp => mp.MapView.IsLinkChartView &&
          mp.MapView.Map.Name == "Acme Link Chart");
        var linkChartMap = mapPane.MapView.Map;
        //Clear all content from the link chart
        if (linkChartMap.CanClearLinkChartContent())
          linkChartMap.ClearLinkChartContent();
    Requirements
    ArcGIS Pro version: 3.7 or higher.
