ArcGIS.Desktop.Mapping Namespace / GridOptions Class / GetGridRotation Method
Example
    Gets the current rotation angle of the grid
    Syntax
    Public Function GetGridRotation() As Double
    public double GetGridRotation()
    Return Value
    The grid rotation in degrees
    Remarks
    Rotation is in degrees from 0 (North) to 360 (North) in a clockwise direction
    Example
    Set Various Grid Option parameters for GridOptions for a Map
        var center_pt = MapView.Active.Extent.Center;
        var width = MapView.Active.Extent.Width;
        var height = MapView.Active.Extent.Height;
        var qtr_width = width * 0.25;
        var qtr_ht = height * 0.25;
        QueuedTask.Run(() =>
            //use defaults
            var gridOptions = GridOptionsEnvironment.Instance.DefaultGridOptions;
            //customize the options as needed
            gridOptions.RotateWithMap = !gridOptions.RotateWithMap;
            gridOptions.GridLineColor = ColorFactory.Instance.RedRGB;
            var gs_rotation = gridOptions.GetGridRotation();
            gridOptions.SetGridRotation(gs_rotation * 1.5);
            var gs_meters = gridOptions.GetGridSpacingMeters();
            var gs_in_spacing_units = gridOptions.GetGridSpacing();
            var gs_units = gridOptions.GridSpacingUnits;
            //meters assumed
            gridOptions.SetGridSpacingInMeters(gs_meters + 10);
            //specify units explicitly
            gridOptions.SetGridSpacing(1000, LinearUnit.Feet);//internally will be converted to meters
            gridOptions.IsGridLines = true;//use lines (default)
            var grid_interval = gridOptions.GridMajorInterval;
            gridOptions.SnapToGridEnabled = true;
            var x1 = center_pt.X - qtr_width;
            var y1 = center_pt.Y + qtr_ht;
            gridOptions.SetGridOrigin(new Coordinate2D(x1, y1));
            //To apply changes, the gridoptions must be set back on the map
            GridOptionsEnvironment.Instance.SetGridOptions(map, gridOptions);
    Requirements
    ArcGIS Pro version: 3.7 or higher.
