Return Value
The grid spacing in meters
var center_pt = MapView.Active.Extent.Center;
var width = MapView.Active.Extent.Width;
var height = MapView.Active.Extent.Height;
var qtr_width = width * 0.25;
var qtr_ht = height * 0.25;
QueuedTask.Run(() =>
//use defaults
var gridOptions = GridOptionsEnvironment.Instance.DefaultGridOptions;
//customize the options as needed
gridOptions.RotateWithMap = !gridOptions.RotateWithMap;
gridOptions.GridLineColor = ColorFactory.Instance.RedRGB;
var gs_rotation = gridOptions.GetGridRotation();
gridOptions.SetGridRotation(gs_rotation * 1.5);
var gs_meters = gridOptions.GetGridSpacingMeters();
var gs_in_spacing_units = gridOptions.GetGridSpacing();
var gs_units = gridOptions.GridSpacingUnits;
//meters assumed
gridOptions.SetGridSpacingInMeters(gs_meters + 10);
//specify units explicitly
gridOptions.SetGridSpacing(1000, LinearUnit.Feet);//internally will be converted to meters
gridOptions.IsGridLines = true;//use lines (default)
var grid_interval = gridOptions.GridMajorInterval;
gridOptions.SnapToGridEnabled = true;
var x1 = center_pt.X - qtr_width;
var y1 = center_pt.Y + qtr_ht;
gridOptions.SetGridOrigin(new Coordinate2D(x1, y1));
//To apply changes, the gridoptions must be set back on the map
GridOptionsEnvironment.Instance.SetGridOptions(map, gridOptions);
