Public Overloads Sub SetGridOrigin( _ ByVal origin3D As Coordinate3D _ )
public void SetGridOrigin( Coordinate3D origin3D )
Parameters
- origin3D
- The origin of the grid. Z value, i.e. grid elevation, must be in meters
//assume
//var map = MapView.Active.Map;
var center_pt = MapView.Active.Extent.Center;
var width = MapView.Active.Extent.Width;
var height = MapView.Active.Extent.Height;
var qtr_width = width * 0.25;
var qtr_ht = height * 0.25;
QueuedTask.Run(() =>
//If grid options have not been set for the map, then default grid options are added
//for the map and returned otherwise the existing gridoptions are returned.
//NOTE: Grid options are by value meaning a copy is returned. Any changes made to the
//grid options need to be -set- back on the map using SetGridOptions for the changes to persist.
var gridOptions = GridOptionsEnvironment.Instance.GetGridOptions(map);
//Set the grid origin
var x1 = center_pt.X + qtr_width;
var y1 = center_pt.Y + qtr_ht;
gridOptions.SetGridOrigin(new Coordinate2D(x1, y1));
//or use Coordinate3D
gridOptions.SetGridOrigin(new Coordinate3D(x1, y1, 0));
//To apply changes, the gridoptions must be set back on the map
GridOptionsEnvironment.Instance.SetGridOptions(map, gridOptions);
