ArcGIS.Desktop.Mapping Namespace / GridOptions Class / GridLineColor Property
Example
    Gets and sets the color of the grid lines
    Syntax
    Public Property GridLineColor As CIMColor
    public CIMColor GridLineColor {get; set;}
    Example
    Get and Set Grid Options for a Map
        //assume
        //var map = MapView.Active.Map;
        QueuedTask.Run(() =>
            //If grid options have not been set for the map, then default grid options are added
            //for the map and returned otherwise the existing gridoptions are returned.
            //NOTE: Grid options are by value meaning a copy is returned. Any changes made to the
            //grid options need to be -set- back on the map using SetGridOptions for the changes to persist.
            var gridOptions = GridOptionsEnvironment.Instance.GetGridOptions(map);
            //change some properties
            gridOptions.RotateWithMap = !gridOptions.RotateWithMap;
            gridOptions.GridLineColor = ColorFactory.Instance.RedRGB;
            gridOptions.GridLineColor = ColorFactory.Instance.BlueRGB;
            //To apply changes, the gridoptions must be set back on the map
            GridOptionsEnvironment.Instance.SetGridOptions(map, gridOptions);
    Set Various Grid Option parameters for GridOptions for a Map
        var center_pt = MapView.Active.Extent.Center;
        var width = MapView.Active.Extent.Width;
        var height = MapView.Active.Extent.Height;
        var qtr_width = width * 0.25;
        var qtr_ht = height * 0.25;
            //use defaults
            var gridOptions = GridOptionsEnvironment.Instance.DefaultGridOptions;
            //customize the options as needed
            var gs_rotation = gridOptions.GetGridRotation();
            gridOptions.SetGridRotation(gs_rotation * 1.5);
            var gs_meters = gridOptions.GetGridSpacingMeters();
            var gs_in_spacing_units = gridOptions.GetGridSpacing();
            var gs_units = gridOptions.GridSpacingUnits;
            //meters assumed
            gridOptions.SetGridSpacingInMeters(gs_meters + 10);
            //specify units explicitly
            gridOptions.SetGridSpacing(1000, LinearUnit.Feet);//internally will be converted to meters
            gridOptions.IsGridLines = true;//use lines (default)
            var grid_interval = gridOptions.GridMajorInterval;
            gridOptions.SnapToGridEnabled = true;
            var x1 = center_pt.X - qtr_width;
            var y1 = center_pt.Y + qtr_ht;
            gridOptions.SetGridOrigin(new Coordinate2D(x1, y1));
    Requirements
    ArcGIS Pro version: 3.7 or higher.
