ArcGIS.Desktop.Mapping Namespace / IGridOptionsEnvironment Interface / DefaultGridOptions Property
Example
    DefaultGridOptions Property (IGridOptionsEnvironment)
    Gets a set of default grid options
    Syntax
    ReadOnly Property DefaultGridOptions As GridOptions
    GridOptions DefaultGridOptions {get;}
    Remarks
    These can be modified as needed and applied to a map. See SetGridOptions
    Example
    Get the Default Grid Options
        QueuedTask.Run(() =>
            var gridOptions = GridOptionsEnvironment.Instance.DefaultGridOptions;
    Reset the Grid Options for a Map back to Defaults
            if (GridOptionsEnvironment.Instance.HasGridOptions(map))
                //set back to defaults - will overwrite existing
                GridOptionsEnvironment.Instance.SetGridOptions(map,
                    GridOptionsEnvironment.Instance.DefaultGridOptions);
    Requirements
    ArcGIS Pro version: 3.7 or higher.
