CIMSymbolAnimationMoveAlongLine Class Members
The following tables list the members exposed by CIMSymbolAnimationMoveAlongLine.
Public Constructors
Public Properties
| | Name | Description |
 | AnimatedSymbolProperties |
Gets or sets the animated symbol properties.
(Inherited from ArcGIS.Core.CIM.CIMSymbolAnimation) |
 | Continuous |
Gets or sets a value indicating whether the animation will loop continuously when Speed is defined.
If true, once the marker reaches the end of the line it will jump back to the starting placement and repeat the animation continuously until the duration is reached.
 | DistanceAlong |
Gets or sets the distance as a percentage along the line to which the marker will animate.
0 corresponds to the starting placement of the marker, and 100 corresponds to a full movement along the line.
This is only used if MovementType is set to Distance.
 | MovementType |
Gets or sets the movement type, indicating whether the marker animates along the line by distance or by speed.
 | PrimitiveName |
Gets or sets the primitive name.
 | Speed |
Gets or sets the speed at which the marker will animate along the line, in units of the line's unit per second.
When the MovementType is set to Distance, the marker will move along the line at this speed until it reaches the DistanceAlong value.
When the MovementType is set to Speed, the marker will move along the line at this speed, and DistanceAlong is ignored.
Top
Public Methods
Public Events
