ArcGIS.Core.OCR Namespace / OCRLine Class
Members Example
    OCRLine Class
    Represents a detected line within a document image. Used within the components of an OCRTSVOutput instance.
    Object Model
    OCRLine ClassOCRBoundingBox Class
    Syntax
    public sealed class OCRLine
    Public NotInheritable Class OCRLine
    Remarks
    The TSV output hierarchy is as follows: - OCRPage -> OCRBlock -> OCRParagraph -> OCRLine -> OCRWord.
    That is, an OCRLine contains a set of OCRWords and a set of OCRLines are in an OCRParagraph.
    Example
    Extract TSV output from a document
      string docFileName = "c:\\MyData\\MyDocument.bmp";
      var ocrOptions = new OCROptions(docFileName);
      ocrOptions.OutputType = OCROutputType.TSV;
      // set a specific page if necessary
      // (if not set, then all pages are scanned)
      // ocrOptions.Page = pageIdx;
      // set the resolution if necessary
      // ocrOptions.Resolution = 400;
      var output = await OCRManager.Instance.ExtractFromDocumentAsync(ocrOptions);
      if (output is OCRTSVOutput ocr_tsvOutput)
        // process the tsv output
        foreach (var page in ocr_tsvOutput.Pages)
          foreach (var block in page.Blocks)
            foreach (var para in block.Paragraphs)
              foreach (var line in para.Lines)
                foreach (var word in line.Words)
                  var content = word.Content;
                  var confidence = word.Confidence;
                  // process content according to confidence
    Get text from TSVOutput (simple)
      string text = "";
      var flowDocument = new FlowDocument();
      foreach (var page in tsvOutput.Pages)
        List<Paragraph> pageParagraphs = new();
          foreach (var paragraph in block.Paragraphs)
            foreach (var line in paragraph.Lines)
              string lineWords = string.Join(" ", line.Words.Select(w => w.Content));
              pageParagraphs.Add(new Paragraph(new Span(new Run(lineWords))));
        flowDocument.Blocks.AddRange(pageParagraphs);
        flowDocument.Blocks.Add(new Paragraph(new Span(new Run(Environment.NewLine))));
      var startPointer = flowDocument?.ContentStart;
      var endPointer = flowDocument?.ContentEnd;
      if (startPointer != null && endPointer != null)
        text = new TextRange(startPointer, endPointer).Text;
    Inheritance Hierarchy
    System.Object
       ArcGIS.Core.OCR.OCRLine
    Requirements
    ArcGIS Pro version: 3.8 or higher.
