ArcGIS.Core.OCR Namespace / OCRManager Class / ExtractTextFromDocumentAsync Method / ExtractTextFromDocumentAsync(String) Method
The document image. See IsValidDocumentForOCR for information about the file extensions supported.
Example
    Extracts text from a document image using the OCROutputType.Text output type. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public Task<string> ExtractTextFromDocumentAsync(
       string documentFileName
    Public Overloads Function ExtractTextFromDocumentAsync( _
       ByVal documentFileName As String _
    ) As Task(Of String)
    Parameters
    documentFileName
    Return Value
    A string containing the text extracted. The string can be empty if no data can be extracted.
    Exceptions
    ExceptionDescription
    documentFileName is null.
    The document image cannot be found or has an invalid extension for OCR.
    An error occurred within the OCR engine.
    Remarks
    Optical Character Recognition (OCR) technology is used to extract text from the document image. Text extraction and character recognition will be dependent on the quality and content of the image. There might also be difficulty in extracting text from complex data.
    If you wish to specify a specific output type or customize other options, use the ExtractFromDocumentAsync(OCROptions) or ExtractFromDocumentAsync(OCROptions,CancellationToken) overloads and set the options such as OCROptions.OutputType as appropriate.
    Example
    Extract text from a document
      string docFileName = "c:\\MyData\\MyDocument.pdf";
      var text = await OCRManager.Instance.ExtractTextFromDocumentAsync(docFileName);
      // or extract from a specific page
      //int pageIdx = 1;
      //var text = await OCRManager.Instance.ExtractTextFromDocumentAsync(deedFileName, pageIdx);
    Requirements
    ArcGIS Pro version: 3.8 or higher.
