| Name | Description | |
![]() | CIMKnowledgeGraphLoadDataPlan Constructor |
The following tables list the members exposed by CIMKnowledgeGraphLoadDataPlan.
![]() | Name | Gets or sets the name of the Load Data Plan. Names are expected to be unique within an Investigation. |
![]() | PlanItems | Gets or sets the Load Data Plan Items referenced by this Plan. |
![]() | Clone | Creates a deep copy of CIMKnowledgeGraphLoadDataPlan. |
![]() ![]() | FromJson | Reconstructs the CIMKnowledgeGraphLoadDataPlan with a specified state from a JSON encoding. |
![]() | GetSchema | Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | ReadXml | Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | ToJson | Overridden. Creates a JSON encoding of the CIMKnowledgeGraphLoadDataPlan and its current state. |
![]() | WriteXml | Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | RaisePropertyChanged | Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | ReadXmlElement | Overridden. Reads the child element inside the reader. |
![]() | WriteXmlElements | Overridden. Writes a child element to the writer. |
![]() | PropertyChanged | Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject) |
