ArcGIS.Core.CIM Namespace / CIMPage Class / Height Property
Example
    Height Property (CIMPage)
    Gets or sets the height of the layout in page units.
    Syntax
    public double Height {get; set;}
    Public Property Height As Double
    Example
    Create report
      await QueuedTask.Run(async () =>
        //The fields in the datasource used for the report
        //This uses a US Cities dataset
        var listFields = new List<CIMReportField> {
              //Grouping should be the first field
              new CIMReportField{Name = "STATE_NAME", FieldOrder = 0, Group = true, SortInfo = FieldSortInfo.Desc}, //Group cities using STATES
              new CIMReportField{Name = "CITY_NAME", FieldOrder = 1},
              new CIMReportField{Name = "POP1990", FieldOrder = 2, },
        //Definition query to use for the data source
        var defQuery = "STATE_NAME LIKE 'C%'";
        //Define the Datasource
        var reportDataSource = new ReportDataSource(featureLayer, defQuery, listFields);
        //The CIMPage defintion - page size, units, etc
        var cimReportPage = new CIMPage
          Height = 11,
          StretchElements = false,
          Width = 6.5,
          ShowRulers = true,
          ShowGuides = true,
          Margin = new CIMMargin { Bottom = 1, Left = 1, Right = 1, Top = 1 },
          Units = LinearUnit.Inches
        //Report template
        var reportTemplates = await ReportTemplateManager.GetTemplatesAsync();
        var reportTemplate = reportTemplates.Where(r => r.Name == "Attribute List with Grouping").First();
        //Report Styling
        var reportStyles = await ReportStylingManager.GetStylingsAsync();
        var reportStyle = reportStyles.Where(s => s == "Cool Tones").First();
        //Field Statistics
        var fieldStatisticsList = new List<ReportFieldStatistic> {
              new ReportFieldStatistic{ Field = "POP1990", Statistic = FieldStatisticsFlag.Sum}
              //Note: NoStatistics option for FieldStatisticsFlag is not supported.
        var newReport = ReportFactory.Instance.CreateReport("USAReport", reportDataSource, cimReportPage, fieldStatisticsList, reportTemplate, reportStyle);
    Modify the report Page
      await QueuedTask.Run(() =>
          Height = 12,
          Width = 6.5,
          ShowRulers = true,
          ShowGuides = true,
        report.SetPage(cimReportPage);
        //Change only the report's page height
        report.SetPageHeight(12);
    Requirements
