Public Property Frame As CIMGraphicFrame
public CIMGraphicFrame Frame {get; set;}
//Note: Must be on QueuedTask.Run
//Create rectangle text with background and border symbology.
//Build 2D polygon geometry
List<Coordinate2D> plyCoords = new List<Coordinate2D>();
plyCoords.Add(new Coordinate2D(3.5, 7));
plyCoords.Add(new Coordinate2D(4.5, 7));
plyCoords.Add(new Coordinate2D(4.5, 6.7));
plyCoords.Add(new Coordinate2D(5.5, 6.7));
plyCoords.Add(new Coordinate2D(5.5, 6.1));
plyCoords.Add(new Coordinate2D(3.5, 6.1));
Polygon poly = PolygonBuilderEx.CreatePolygon(plyCoords);
//Set symbology, create and add element to layout
//Also notice how formatting tags are using within the text string.
CIMTextSymbol sym = SymbolFactory.Instance.ConstructTextSymbol(
ColorFactory.Instance.GreyRGB, 10, "Arial", "Regular");
string text = "Some Text String that is really long and is " +
"<BOL>forced to wrap to other lines</BOL> so that " +
"we can see the effects." as String;
GraphicElement polyTxtElm = ElementFactory.Instance.CreateTextGraphicElement(
layout, TextType.RectangleParagraph, poly, sym, text, "Polygon Paragraph");
//(Optionally) Modify paragraph border
CIMGraphic polyTxtGra = polyTxtElm.GetGraphic();
CIMParagraphTextGraphic cimPolyTxtGra = polyTxtGra as CIMParagraphTextGraphic;
cimPolyTxtGra.Frame.BorderSymbol = new CIMSymbolReference();
cimPolyTxtGra.Frame.BorderSymbol.Symbol =
SymbolFactory.Instance.ConstructLineSymbol(
ColorFactory.Instance.GreyRGB, 1.0, SimpleLineStyle.Solid);
polyTxtElm.SetGraphic(polyTxtGra);
