Public Overloads Sub Modify( _ ByVal tableDescription As TableDescription _ )
public void Modify( TableDescription tableDescription )
Parameters
- tableDescription
- Indicates the ArcGIS.Core.Data.Table to be modified.
| Exception | Description |
| System.ArgumentException | The subtypes are invalid. |
| System.ArgumentNullException | tableDescription is null. |
| ArcGIS.Core.CalledOnWrongThreadException | This method or property must be called within the lambda passed to QueuedTask.Run. |
// Must be called within QueuedTask.Run
void RemoveFieldTableSnippet(Geodatabase geodatabase)
// Removing all fields from 'Parcels' table except following
// Tax_Code
// Parcel_Address
// The table to remove fields
string tableName = "Parcels";
TableDefinition tableDefinition = geodatabase.GetDefinition<TableDefinition>(tableName);
IReadOnlyList<Field> fields = tableDefinition.GetFields();
// Existing fields from 'Parcels' table
Field taxCodeField = fields.First(f => f.Name.Equals("Tax_Code"));
Field parcelAddressField = fields.First(f => f.Name.Equals("Parcel_Address"));
FieldDescription taxFieldDescription = new FieldDescription(taxCodeField);
FieldDescription parcelAddressFieldDescription = new FieldDescription(parcelAddressField);
// Fields to retain in modified table
List<FieldDescription> fieldsToBeRetained = new List<FieldDescription>()
taxFieldDescription, parcelAddressFieldDescription
// New description of the 'Parcels' table with the 'Tax_Code' and 'Parcel_Address' fields
TableDescription modifiedTableDescription = new TableDescription(tableName, fieldsToBeRetained);
SchemaBuilder schemaBuilder = new SchemaBuilder(geodatabase);
// Remove all fields except the 'Tax_Code' and 'Parcel_Address' fields
schemaBuilder.Modify(modifiedTableDescription);
schemaBuilder.Build();
void ModifyDomain(Geodatabase geodatabase, string codedValueDomainName = "Pipe")
CodedValueDomain codedValueDomain = geodatabase.GetDomains().First(f => f.GetName().Equals(codedValueDomainName)) as CodedValueDomain;
CodedValueDomainDescription codedValueDomainDescription = new CodedValueDomainDescription(codedValueDomain);
// Update domain description
codedValueDomainDescription.Description = "Water Pipe Domain";
// Adding code/value pair
codedValueDomainDescription.CodedValuePairs.Add("C", "Copper");
schemaBuilder.Modify(codedValueDomainDescription);
// To modify the orders of coded value domain
// schemaBuilder.Modify(codedValueDomainDescription,SortBy.Name,SortOrder.Ascending);
void DeleteSubtypeField(SchemaBuilder schemaBuilder, FeatureClassDefinition featureClassDefinition)
FeatureClassDescription featureClassDescription = new FeatureClassDescription(featureClassDefinition);
// Set subtype field to null to remove the subtype field designation
featureClassDescription.SubtypeFieldDescription = null;
schemaBuilder.Modify(featureClassDescription);
void ModifySubtypes(SchemaBuilder schemaBuilder, TableDefinition tableDefinition)
TableDescription tableDescription = new TableDescription(tableDefinition);
// Remove the first subtype from the table
IReadOnlyList<Subtype> subtypes = tableDefinition.GetSubtypes();
tableDescription.SubtypeFieldDescription.Subtypes.Remove(subtypes.First().GetCode());
// Adding a new subtype, 'Utility', in the existing table
tableDescription.SubtypeFieldDescription.Subtypes.Add(4, "Utility");
// Assigning 'Utility' subtype as the default subtype
tableDescription.SubtypeFieldDescription.DefaultSubtypeCode = 4;
schemaBuilder.Modify(tableDescription);
void ModifyRelationshipClass(SchemaBuilder schemaBuilder, AttributedRelationshipClassDefinition attributedRelationshipClassDefinition)
AttributedRelationshipClassDescription attributedRelationshipClassDescription = new AttributedRelationshipClassDescription(attributedRelationshipClassDefinition);
// Update the relationship split policy
attributedRelationshipClassDescription.RelationshipSplitPolicy = RelationshipSplitPolicy.UseDefault;
// Add field in the intermediate table
attributedRelationshipClassDescription.FieldDescriptions.Add(FieldDescription.CreateIntegerField("RelationshipStatus"));
// Add relationship rules based on subtypes,if available
// Assuming origin class has subtype with code 1
attributedRelationshipClassDescription.RelationshipRuleDescriptions.Add(
new RelationshipRuleDescription(1, null));
// Enqueue modify operation
schemaBuilder.Modify(attributedRelationshipClassDescription);
// Execute modify DDL operation
void ModifyAnnotationLabelAndSymbols(SchemaBuilder schemaBuilder, AnnotationFeatureClassDefinition annotationFeatureClassDefinition)
AnnotationFeatureClassDescription annotationFeatureClassDescription = new AnnotationFeatureClassDescription(annotationFeatureClassDefinition);
IReadOnlyList<CIMLabelClass> labelClasses = annotationFeatureClassDescription.LabelClasses;
// Adding a new annotation label class
List<CIMLabelClass> modifiedLabelClasses = new List<CIMLabelClass>(labelClasses);
modifiedLabelClasses.Add(new CIMLabelClass()
Name = "RedSymbol",
TextSymbol = new CIMSymbolReference
Symbol = new CIMTextSymbol()
Angle = 45,
FontType = FontType.Type1,
FontFamilyName = "Arial",
FontEffects = FontEffects.Normal,
HaloSize = 2.0,
Symbol = new CIMPolygonSymbol
SymbolLayers = new CIMSymbolLayer[]
{ new CIMSolidFill { Color = CIMColor.CreateRGBColor(255, 0, 0) } },
UseRealWorldSymbolSizes = true
MaxScale = 0,
MinScale = 0,
SymbolName = "TextSymbol-RED"
// Adding a new symbol
annotationFeatureClassDescription.Symbols.Add(new CIMSymbolIdentifier()
ID = 1001,
Name = "ID_10001",
Angle = 43,
FontEffects = FontEffects.Subscript,
FontType = FontType.TTOpenType,
FontStyleName = "Regular",
FontFamilyName = "Tahoma",
TextCase = TextCase.Allcaps
// Modify annotation feature class
AnnotationFeatureClassDescription modifiedAnnotationFeatureClassDescription = new AnnotationFeatureClassDescription(annotationFeatureClassDescription.Name,
annotationFeatureClassDescription.FieldDescriptions, annotationFeatureClassDescription.ShapeDescription,
annotationFeatureClassDescription.GeneralPlacementProperties, modifiedLabelClasses);
// Enqueue modify
schemaBuilder.Modify(modifiedAnnotationFeatureClassDescription);
// DDL execute
void ModifyExistingField(SchemaBuilder schemaBuilder, TableDefinition tableDefinition, string fieldNameToBeModified = "PropertyAddress")
Field field = tableDefinition.GetFields().FirstOrDefault(f => f.Name.Contains(fieldNameToBeModified));
// Update field's alias name and length
FieldDescription fieldDescription = new FieldDescription(field)
AliasName = "Physical Property Address",
Length = 50
// Update the default value
fieldDescription.SetDefaultValue("123 Main St");
schemaBuilder.Modify(new TableDescription(tableDefinition), field.Name, fieldDescription);
// Execute DDL
