ArcGIS.Core.CIM Namespace / CIMPolygonGraphic Class / ReadXmlElement Method
System.Xml.XmlReader
Example
    ReadXmlElement Method (CIMPolygonGraphic)
    Reads the child element inside the reader.
    Syntax
    Protected Overrides Function ReadXmlElement( _
       ByVal reader As XmlReader _
    ) As Boolean
    protected override bool ReadXmlElement(
       XmlReader reader
    Parameters
    reader
    Example
    Polygon Graphic Element using CIMGraphic
      // Note: must be called on the QueuedTask
        //On the QueuedTask
        //Place a polygon symbol using the mapview extent geometry
        var extent = MapView.Active.Extent;
        //Contract the extent
        var polygonEnv = extent.Expand(-100000, -90000, false);
        //create a polygon using the envelope
        var polygon = PolygonBuilderEx.CreatePolygon(polygonEnv);
        //specify a symbol
        var poly_symbol = SymbolFactory.Instance.ConstructPolygonSymbol(
                              ColorFactory.Instance.GreenRGB);
        //create a CIMGraphic
        var graphic = new CIMPolygonGraphic()
          Symbol = poly_symbol.MakeSymbolReference(),
          Polygon = polygon,
        graphicsLayer.AddElement(graphic);
    Requirements
