ArcGIS.Core.CIM Namespace / CIMProportionalPieSizeOptions Class
Properties Methods Events
    CIMProportionalPieSizeOptions Class Members
    The following tables list the members exposed by CIMProportionalPieSizeOptions.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets a value indicating whether or not to use Flannery compensation.
    Public Property Gets or sets the maximum size.
    Public Property Gets or sets the data value that corresponds to the maximum size.
    Public Property Gets or sets the minimum size.
    Public Property Gets or sets the data value that corresponds to the minimum size.
    Public Property Gets or sets a value indicating whether to size the pie chart proportionally by the sum of field values.
    Public Property Gets or sets the Arcade expression that is used to size the pie chart proportionally.
    Public Property Gets or sets the field that is used to size the pie chart proportionally.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMProportionalPieSizeOptions.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMProportionalPieSizeOptions with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMProportionalPieSizeOptions and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
