ArcGIS.Core.CIM Namespace / CIMAutoCamera Class / Extent Property
Example
    Extent Property (CIMAutoCamera)
    Gets or sets the extent for a map frame when using the fixed constraint.
    Syntax
    Public Property Extent As Envelope
    public Envelope Extent {get; set;}
    Example
    SetAutoCameraFixedExtent
      var autoCamera = mapFrame.GetAutoCamera();
      autoCamera.Source = AutoCameraSource.Fixed;
      autoCamera.AutoCameraType = AutoCameraType.Extent;
      var mf_extent = mapFrame.GetViewExtent();
      var extent = EnvelopeBuilderEx.CreateEnvelope(
        400748.62, 800296.4, 1310669.05, 1424520.74, mapFrame.Map.SpatialReference);
      autoCamera.Extent = extent;
      if (mapFrame.ValidateAutoCamera(autoCamera) &&
        !mapFrame.IsMapSeriesMapFrame())
        mapFrame.SetAutoCamera(autoCamera);
    Requirements
