ArcGIS.Core.CIM Namespace / CIMAutoCamera Class
Properties Methods Events
    CIMAutoCamera Class Members
    The following tables list the members exposed by CIMAutoCamera.
    Public Constructors
     NameDescription
    Public Constructor
    Top
    Public Properties
     NameDescription
    Public Property Gets or sets the camera type.
    Public Property Gets or sets the camera associated with the map frame.
    Public Property Gets or sets the extent for a map frame when using the fixed constraint.
    Public Property Gets or sets the layer being used to set the camera when using the map frame link constraint.
    Public Property Gets or sets the map frame name being used to set the camera when using the map frame link constraint.
    Public Property Gets or sets the margin value for a map frame with a map frame link constraint.
    Public Property Gets or sets the margin type for a map frame with a map frame link constraint.
    Public Property Gets or sets the margin units for a map frame with a map frame link constraint.
    Public Property Gets or sets the extent constraint associated with the map frame.
    Public Property Gets or sets a value indicating whether the map frame should rotate when using a map frame link constraint.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMAutoCamera.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMAutoCamera with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMAutoCamera and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
