| Name | Description | |
![]() | CIMRasterTable Constructor |
The following tables list the members exposed by CIMRasterTable.
![]() | ActiveRangeName | Gets or sets the active range name. (Inherited from ArcGIS.Core.CIM.CIMDisplayTable) |
![]() | BindVariables | Gets or sets the bind variables. (Inherited from ArcGIS.Core.CIM.CIMDisplayTable) |
![]() | DatabaseRelates | Gets or sets overrides for database relationships as relationship info. |
![]() | DefinitionExpression | Gets or sets the definition expression that can subset the rows in the layer or table. (Inherited from ArcGIS.Core.CIM.CIMDisplayTable) |
![]() | DefinitionExpressionName | Gets or sets the name of the active definition expression. (Inherited from ArcGIS.Core.CIM.CIMDisplayTable) |
![]() | DefinitionFilterChoices | Gets or sets the definition filter choices. (Inherited from ArcGIS.Core.CIM.CIMDisplayTable) |
![]() | DisplayExpressionInfo | Gets or sets the expression information used for coming up with a string that represents a row or a feature. This property takes precedence over DisplayField. (Inherited from ArcGIS.Core.CIM.CIMDisplayTable) |
![]() | DisplayField | Gets or sets the name of the attribute field that will be used as a label that represents each row in the layer or table. The display field must be able to be represented as a string (string or numeric). (Inherited from ArcGIS.Core.CIM.CIMDisplayTable) |
![]() | Editable | Gets or sets a value indicating whether or not the layer or table can be edited. (Inherited from ArcGIS.Core.CIM.CIMDisplayTable) |
![]() | FieldDescriptions | Gets or sets the field descriptions. Field descriptions for fields may only be written if values are overridden from defaults. (Inherited from ArcGIS.Core.CIM.CIMDisplayTable) |
![]() | FloorAwareTableProperties | Gets or sets floor-aware properties for the layer or table used in floor filtering. (Inherited from ArcGIS.Core.CIM.CIMDisplayTable) |
![]() | FormInfo | Gets or sets the form information for the layer or table. (Inherited from ArcGIS.Core.CIM.CIMDisplayTable) |
![]() | Joins | Gets or sets the joins as a data connection. |
![]() | RangeDefinitions | Gets or sets the range definitions. (Inherited from ArcGIS.Core.CIM.CIMDisplayTable) |
![]() | Relates | Gets or sets the relates. (Inherited from ArcGIS.Core.CIM.CIMDisplayTable) |
![]() | RouteIDFieldName | Gets or sets the route identifier field of a route feature class. (Inherited from ArcGIS.Core.CIM.CIMDisplayTable) |
![]() | SelectionSetURI | Gets or sets the URI of the selection set for the layer or table. (Inherited from ArcGIS.Core.CIM.CIMDisplayTable) |
![]() | SelectRelatedData | Gets or sets a value indicating whether related data should be selected when creating a new selection. (Inherited from ArcGIS.Core.CIM.CIMDisplayTable) |
![]() | SubtypeValue | Gets or sets the subtype value that should be used in the feature layer definition. This property is honored only when feature layer is a member of SubtypeLayer. (Inherited from ArcGIS.Core.CIM.CIMDisplayTable) |
![]() | TimeDefinition | Gets or sets the time definition. (Inherited from ArcGIS.Core.CIM.CIMDisplayTable) |
![]() | TimeDimensionFields | Gets or sets the time definition fields. (Inherited from ArcGIS.Core.CIM.CIMDisplayTable) |
![]() | TimeDisplayDefinition | Gets or sets the time display definition. (Inherited from ArcGIS.Core.CIM.CIMDisplayTable) |
![]() | TimeFields | Gets or sets the time fields. (Inherited from ArcGIS.Core.CIM.CIMDisplayTable) |
![]() | UseSubtypeValue | Gets or sets a value indicating whether or not the SubtypeValue should be used. (Inherited from ArcGIS.Core.CIM.CIMDisplayTable) |
![]() | Clone | Creates a deep copy of CIMRasterTable. |
![]() ![]() | FromJson | Reconstructs the CIMRasterTable with a specified state from a JSON encoding. |
![]() | GetSchema | Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | ReadXml | Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | ToJson | Overridden. Creates a JSON encoding of the CIMRasterTable and its current state. |
![]() | WriteXml | Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | RaisePropertyChanged | Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject) |
![]() | ReadXmlElement | Overridden. Reads the child element inside the reader. |
![]() | WriteXmlElements | Overridden. Writes a child element to the writer. |
![]() | PropertyChanged | Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject) |
