ArcGIS.Core.CIM Namespace / CIMBalloonCallout Class
Properties Methods Events
    CIMBalloonCallout Class Members
    The following tables list the members exposed by CIMBalloonCallout.
    Public Constructors
     NameDescription
    Public Constructor
    Top
    Public Properties
     NameDescription
    Public Property Gets or sets the symbol used to draw the background.
    Public Property Gets or sets the balloon style.
    Public Property Gets or sets a symbol used to draw the dart.
    Public Property Gets or sets the dart width.
    Public Property Gets or sets the leader offset which is an offset value defining the distance (in points) between the anchor point and the beginning of the drawn leader. (Inherited from ArcGIS.Core.CIM.CIMCallout)
    Public Property Gets or sets the leader tolerance which is the closest distance (in points) to the text the anchor point can be for the callout to draw. (Inherited from ArcGIS.Core.CIM.CIMCallout)
    Public Property Gets or sets the text margin defining the space around the text that is accounted for in balloon creation.
    Public Property Gets or sets a value indicating whether the dart symbol is drawn differently to the background symbol.
    Public Property Gets or sets a value indicating whether to use a fixed size when drawing the dart symbol.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMBalloonCallout.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMBalloonCallout with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMBalloonCallout and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
