ArcGIS.Core.CIM Namespace / CIMStandardGeneralPlacementProperties Class
Properties Methods Events
    CIMStandardGeneralPlacementProperties Class Members
    The following tables list the members exposed by CIMStandardGeneralPlacementProperties.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets a value indicating whether or not to draw unplaced labels. (Inherited from ArcGIS.Core.CIM.CIMGeneralPlacementProperties)
    Public Property Gets or sets the inverted label tolerance which is the angle at which the label orientation is switched. (Inherited from ArcGIS.Core.CIM.CIMGeneralPlacementProperties)
    Public Property Gets or sets a value indicating whether or not rotate labels when the display rotates. (Inherited from ArcGIS.Core.CIM.CIMGeneralPlacementProperties)
    Public Property Gets or sets the unplaced label color. (Inherited from ArcGIS.Core.CIM.CIMGeneralPlacementProperties)
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMStandardGeneralPlacementProperties.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMStandardGeneralPlacementProperties with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMStandardGeneralPlacementProperties and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
