ArcGIS.Core.CIM Namespace / CIMStandardLineLabelPosition Class / ProduceCurvedLabels Property
Example
    Gets or sets a value indicating whether or not to produce curved labels.
    Syntax
    Public Property ProduceCurvedLabels As Boolean
    public bool ProduceCurvedLabels {get; set;}
    Example
    Modify the Placement/Position of labels - Line geometry
      // Note: call within QueuedTask.Run()
        //Get the layer's definition
        var lyrDefn = featureLayer.GetDefinition() as CIMFeatureLayer;
        //Get the label classes - we need the first one
        var listLabelClasses = lyrDefn.LabelClasses.ToList();
        var theLabelClass = listLabelClasses.FirstOrDefault();
        //Modify label Placement
        //Check if the label engine is Maplex or standard.
        CIMGeneralPlacementProperties labelEngine =
            MapView.Active.Map.GetDefinition().GeneralPlacementProperties;
        if (labelEngine is CIMStandardGeneralPlacementProperties)
          //Current labeling engine is Standard labeling engine
          var lineLablePosition = new CIMStandardLineLabelPosition
            Perpendicular = true,
            Parallel = false,
            ProduceCurvedLabels = false,
            Horizontal = false,
            OnTop = true
          theLabelClass.StandardLabelPlacementProperties.LineLabelPosition =
              lineLablePosition;
        else //Current labeling engine is Maplex labeling engine
          theLabelClass.MaplexLabelPlacementProperties.LinePlacementMethod =
                        MaplexLinePlacementMethod.CenteredPerpendicularOnLine;
          theLabelClass.MaplexLabelPlacementProperties.LineFeatureType =
                        MaplexLineFeatureType.General;
        //theLabelClass.MaplexLabelPlacementProperties.LinePlacementMethod = MaplexLinePlacementMethod.CenteredPerpendicularOnLine;
        lyrDefn.LabelClasses = listLabelClasses.ToArray(); //Set the labelClasses back
        featureLayer.SetDefinition(lyrDefn); //set the layer's definition
    Requirements
