ArcGIS.Core.CIM Namespace / CIMStandardLineLabelPriorities Class
Properties Methods Events
    CIMStandardLineLabelPriorities Class Members
    The following tables list the members exposed by CIMStandardLineLabelPriorities.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the label position priority for above and after the line.
    Public Property Gets or sets the label position priority for above and along the line.
    Public Property Gets or sets the label position priority for above and before the line.
    Public Property Gets or sets the label position priority for above and at the end of the line.
    Public Property Gets or sets the label position priority for above and at the start of the line.
    Public Property Gets or sets the label position priority for below and after the line.
    Public Property Gets or sets the label position priority for below and along the line.
    Public Property Gets or sets the label position priority for below and before the line.
    Public Property Gets or sets the label position priority for below and at the end of the line.
    Public Property Gets or sets the label position priority for below and at the start of the line.
    Public Property Gets or sets the label position priority for centered and after the line.
    Public Property Gets or sets the label position priority for centered and along the line.
    Public Property Gets or sets the label position priority for centered and before the line.
    Public Property Gets or sets the label position priority for centered and at the end of the line.
    Public Property Gets or sets the label position priority for centered and at the start of the line.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMStandardLineLabelPriorities.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMStandardLineLabelPriorities with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMStandardLineLabelPriorities and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
