ArcGIS.Core.CIM Namespace / CIMStandardPointPlacementPriorities Class
Properties Methods Events
    CIMStandardPointPlacementPriorities Class Members
    The following tables list the members exposed by CIMStandardPointPlacementPriorities.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the label position priority for the above center position.
    Public Property Gets or sets the label position priority for the above left position.
    Public Property Gets or sets the label position priority for the above right position.
    Public Property Gets or sets the label position priority for the below center position.
    Public Property Gets or sets the label position priority for the below left position.
    Public Property Gets or sets the label position priority for the below right position.
    Public Property Gets or sets the label position priority for the center left position.
    Public Property Gets or sets the label position priority for the center right position.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMStandardPointPlacementPriorities.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMStandardPointPlacementPriorities with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMStandardPointPlacementPriorities and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
