ArcGIS.Core.CIM Namespace / CIMBasicFeatureLayer Class / UseSelectionSymbol Property
Example
    UseSelectionSymbol Property (CIMBasicFeatureLayer)
    Gets or sets a value indicating whether to use the selection symbol.
    Syntax
    Public Property UseSelectionSymbol As Boolean
    public bool UseSelectionSymbol {get; set;}
    Example
    Change the layer selection color
        // get the CIM definition of the layer
        // Note: needs to be called on the MCT
        var layerDef = featureLayer.GetDefinition() as ArcGIS.Core.CIM.CIMBasicFeatureLayer;
        // disable the default symbol
        layerDef.UseSelectionSymbol = false;
        // assign a new color
        layerDef.SelectionColor = ColorFactory.Instance.RedRGB;
        // apply the definition to the layer
        featureLayer.SetDefinition(layerDef);
        if (!featureLayer.IsVisible)
            featureLayer.SetVisibility(true);
        //Do a selection
        MapView.Active.SelectFeatures(MapView.Active.Extent);
    Requirements
