ArcGIS.Core.CIM Namespace / CIMCallout Class
Properties Methods Events
    CIMCallout Class Members
    The following tables list the members exposed by CIMCallout.
    Public Properties
     NameDescription
    Public Property Gets or sets the leader offset which is an offset value defining the distance (in points) between the anchor point and the beginning of the drawn leader.
    Public Property Gets or sets the leader tolerance which is the closest distance (in points) to the text the anchor point can be for the callout to draw.
    Top
    Public Methods
     NameDescription
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Creates a JSON encoding of the CIMObject and its current state. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
