ArcGIS.Core.CIM Namespace / CIMCGAAttribute Class
Properties Methods Events
    CIMCGAAttribute Class Members
    The following tables list the members exposed by CIMCGAAttribute.
    Public Constructors
     NameDescription
    Public Constructor
    Top
    Public Properties
     NameDescription
    Public Property Gets or sets the count of rows in the array. Used when CGAAttributeType is Float_Array, String_Array and Boolean_Array.
    Public Property Gets or sets the CGA attribute type.
    Public Property Gets or sets the name.
    Public Property Gets or sets the value. Used when CGAAttributeType is Float, String and Boolean.
    Public Property Gets or sets the values in the array. Used when CGAAttributeType is Float_Array, String_Array and Boolean_Array.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMCGAAttribute.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMCGAAttribute with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMCGAAttribute and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
