ArcGIS.Core.CIM Namespace / CIMVisualVariableInfo Class
Properties Methods Events
    CIMVisualVariableInfo Class Members
    The following tables list the members exposed by CIMVisualVariableInfo.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the expression.
    Public Property Gets or sets the random max.
    Public Property Gets or sets the random min.
    Public Property Gets or sets ExpressionInfo that contains the Arcade expression that returns value as a number.
    Public Property Gets or sets the visual variable info type.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMVisualVariableInfo.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMVisualVariableInfo with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMVisualVariableInfo and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
