ArcGIS.Desktop.Mapping Namespace / FeatureSceneLayer Class / SetRenderer Method
Your custom renderer that will be used to draw nodes of the feature scene layer.
    SetRenderer Method (FeatureSceneLayer)
    Specifies the feature scene layer's renderer object which determines how the layer draws. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    public void SetRenderer(
       CIMRenderer renderer
    Public Sub SetRenderer( _
       ByVal renderer As CIMRenderer _
    Parameters
    renderer
    Exceptions
    ExceptionDescription
    Requirements
