ArcGIS.Core.CIM Namespace / CIMWMTSServiceConnection Class / ServerConnection Property
Example
    ServerConnection Property (CIMWMTSServiceConnection)
    Gets or sets the server connection.
    Syntax
    public CIMInternetServerConnectionBase ServerConnection {get; set;}
    Public Property ServerConnection As CIMInternetServerConnectionBase
    Example
    Add a WMTS service
      // Create a connection to the WMS server
      var serverConnection = new CIMProjectServerConnection
        URL = "URL of the WMTS service.xml",
        ServerType = ServerType.WMTS,
      var service_connection = new CIMWMTSServiceConnection
        ServerConnection = serverConnection,
        LayerName = "AdminBoundaries", // Specify the layer name you want to add
      // Add a new layer to the map
      var layerParams = new LayerCreationParams(service_connection);
      layerParams.MapMemberPosition = MapMemberPosition.AddToBottom;
      var layerCreated = await QueuedTask.Run(() =>
        LayerFactory.Instance.CreateLayer<FeatureLayer>(layerParams, map));
    Requirements
