ArcGIS.Core.CIM Namespace / CIMWMTSServiceConnection Class
Properties Methods Events
    CIMWMTSServiceConnection Class Members
    The following tables list the members exposed by CIMWMTSServiceConnection.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets or sets the connection capabilities parameters as a property set.
    Public Property Gets or sets the description. (Inherited from ArcGIS.Core.CIM.CIMServiceConnection)
    Public Property Gets or sets the dimensions as a property set.
    Public Property Gets or sets the image format.
    Public Property Gets or sets the layer name.
    Public Property Gets or sets the custom map parameters as a property set.
    Public Property Gets or sets the server connection.
    Public Property Gets or sets the style.
    Public Property Gets or sets the template url that can be used for tile requests.
    Public Property Gets or sets the tile matrix set.
    Public Property Gets or sets the version.
    Top
    Public Methods
     NameDescription
    Public Method Creates a deep copy of CIMWMTSServiceConnection.
    Public Methodstatic (Shared in Visual Basic) Reconstructs the CIMWMTSServiceConnection with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the CIMWMTSServiceConnection and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
