ArcGIS.Core.CIM Namespace / NACompactStreetDirectionsAgent Class
Properties Methods Events
    NACompactStreetDirectionsAgent Class Members
    The following tables list the members exposed by NACompactStreetDirectionsAgent.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Gets and sets the language to use when generating directions. (Inherited from ArcGIS.Core.CIM.NAStreetDirectionsAgentDefinition)
    Public Property Gets and sets the length units. (Inherited from ArcGIS.Core.CIM.NAStreetDirectionsAgentDefinition)
    Public Property Gets and sets the type of line(s) generated. (Inherited from ArcGIS.Core.CIM.NAStreetDirectionsAgentDefinition)
    Public Property Gets and sets the style name to use when generating directions. (Inherited from ArcGIS.Core.CIM.NAStreetDirectionsAgentDefinition)
    Public Property Gets and sets the network attribute for time calculation. (Inherited from ArcGIS.Core.CIM.NAStreetDirectionsAgentDefinition)
    Top
    Public Methods
     NameDescription
    Public Methodstatic (Shared in Visual Basic) Reconstructs the NACompactStreetDirectionsAgent with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the NACompactStreetDirectionsAgent and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected Method Reads the child element inside the reader. (Inherited from ArcGIS.Core.CIM.NAStreetDirectionsAgentDefinition)
    Protected Method Writes a child element to the writer. (Inherited from ArcGIS.Core.CIM.NAStreetDirectionsAgentDefinition)
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
