ArcGIS.Core.CIM Namespace / NAStreetDirectionsAgent Class
Properties Methods Events
    NAStreetDirectionsAgent Class Members
    The following tables list the members exposed by NAStreetDirectionsAgent.
    Public Constructors
    Public Properties
     NameDescription
    Public Property Get and sets a boolean which indicates if time is displayed in directions.
    Public Property Gets and sets the language to use when generating directions. (Inherited from ArcGIS.Core.CIM.NAStreetDirectionsAgentDefinition)
    Public Property Gets and sets the length units. (Inherited from ArcGIS.Core.CIM.NAStreetDirectionsAgentDefinition)
    Public Property Gets and sets the type of line(s) generated. (Inherited from ArcGIS.Core.CIM.NAStreetDirectionsAgentDefinition)
    Public Property Gets and sets the style name to use when generating directions. (Inherited from ArcGIS.Core.CIM.NAStreetDirectionsAgentDefinition)
    Public Property Gets and sets the network attribute for time calculation. (Inherited from ArcGIS.Core.CIM.NAStreetDirectionsAgentDefinition)
    Top
    Public Methods
     NameDescription
    Public Methodstatic (Shared in Visual Basic) Reconstructs the NAStreetDirectionsAgent with a specified state from a JSON encoding.
    Public Method Not implemented, reserved for future use. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public Method Reads the element inside the reader. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Public MethodOverridden.  Creates a JSON encoding of the NAStreetDirectionsAgent and its current state.
    Public Method Writes the element inside the writer. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
    Protected Methods
     NameDescription
    Protected Method Called from a property setter to notify the framework that an Object member has changed. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Protected MethodOverridden.  Reads the child element inside the reader.
    Protected MethodOverridden.  Writes a child element to the writer.
    Top
    Public Events
     NameDescription
    Public Event Occurs when a property value changes. (Inherited from ArcGIS.Core.CIM.CIMObject)
    Top
