ArcGIS.Core.CIM Namespace / StatsHistogram Class / min Property
Example
    min Property (StatsHistogram)
    Gets and sets the minimum.
    Syntax
    public Nullable<double> min {get; set;}
    Public Property min As Nullable(Of Double)
    Example
    Calculate Raster statistics
    //If a raster dataset has statistics, you can create a raster layer and get these statistics by accessing the colorizer.
    var rasterStatisticsMapView = MapView.Active;
    if (rasterStatisticsMapView == null)
      return;
    await QueuedTask.Run(() =>
      //Accessing the raster layer
      var lyr = rasterStatisticsMapView.Map.GetLayersAsFlattenedList().OfType<BasicRasterLayer>().FirstOrDefault();
      //Getting the colorizer
      var colorizer = lyr.GetColorizer() as CIMRasterStretchColorizer;
      //Accessing the statistics
      var stats = colorizer.StretchStats;
      var max = stats.max;
      var min = stats.min;
    Requirements
