ArcGIS.Core.Data Namespace / Dataset Class
    Dataset Class Methods
    For a list of all members of this type, see Dataset members.
    Public Methods
     NameDescription
    Public Method (Inherited from ArcGIS.Core.CoreObjectsBase)
    Public Method Gets the data store of this dataset. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodGets the Definition of the dataset.
    Public Method Gets the name of the dataset. This method must be called on the MCT. Use QueuedTask.Run.
    Public Method Gets the URI path to the dataset. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodGets the RegistrationType of a dataset. This method must be called on the MCT. Use QueuedTask.Run.
    Top
    Extension Methods
     NameDescription
    Public Extension Method Gets the CIMDataConnection for the specified dataset. This method must be called on the MCT. Use QueuedTask.Run.
    Public Extension Method Gets whether the dataset is a knowledge graph dataset or not. This method must be called on the MCT. Use QueuedTask.Run.
    Top
