ArcGIS.Core.Data Namespace / FeatureDataset Class / OpenDataset<T> Method
The type of dataset to open.
The name of the dataset to open.
    OpenDataset<T> Method (FeatureDataset)
    Gets a specific Dataset instance associated with name of type T in the feature dataset. This method must be called on the MCT. Use QueuedTask.Run.
    Syntax
    Public Function OpenDataset(Of T As Dataset)( _
       ByVal name As String _
    ) As T
    public T OpenDataset<T>(
       string name
    where T: Dataset
    Parameters
    name
    Type Parameters
    T
    Return Value
    A specific Dataset instance corresponding to type T.
    Exceptions
    ExceptionDescription
    T is not currently supported as a dataset type (see DatasetType), or using AttributedRelationshipClass as T to open a dataset whose type is actually DatasetType.RelationshipClass.
    A geodatabase-related exception has occurred.
    Requirements
