ArcGIS.Core.Data Namespace / Field Class
    Field Class Methods
    For a list of all members of this type, see Field members.
    Public Methods
     NameDescription
    Public Method (Inherited from ArcGIS.Core.CoreObjectsBase)
    Public MethodGets the field's default value at the table level if subtype is not set. Otherwise, gets the field's default value for the specific subtype. This method must be called on the MCT. Use QueuedTask.Run.
    Public MethodGets the field's Domain at the table level if subtype is not set. Otherwise, gets the field's domain for the specific subtype. This method must be called on the MCT. Use QueuedTask.Run.
    Top
